updated
873 9 2017-12-19
outbackmac
Flight distance : 489 ft
i updated firmware and dji go app and now when i launch the app i get internet may not be available.  also the drone keeps buzzing off and on and link light blinks red than green.  help
2017-12-19
ALABAMA
Flight distance : 10442687 ft
Don't worry about what it says about internet.  Sounds like you need to relink the AC.
2017-12-19
JackA
Flight distance : 32057 ft
The DJI Wi-fi connection between the Remote Control the Phantom 3 (STD) and the viewing device originates from the Remote Control.  It is not designed to have access to the Internet in genderal so your viewing device reports that you have joined a Wi-Fi network but you do not have Internet access.  It is not a problem in our case because we are not needing Internet access.
2017-12-19
Peterx
Flight distance : 1499708 ft
The link button is blinking red and then green? Take a small wooden stick and tab in the RC menu of the Go app >relink RC to AC< and push the link button one short and gently. If the button gives a solid green light then you can use the P3S system for take off. Internet is not needed to control your bird.
2017-12-19
outbackmac
thanks for all the info  good to have you guys around.  Merry christmas
2017-12-20
DJI Elektra
outbackmac Posted at 2017-12-20 19:29
Hi, sir. Did you solve the problem? If not, please try to flash the firmware and relink the RC and AC.
2017-12-24
RedHotPoker
Flight distance : 165105 ft
Hopefully that relinking tutorial has helped the OP get the drone to cooperate.
It is frustrating, when we have to rebind the RC to the aircraft.
RedHotPoker
2017-12-24
AMARdji2017
DJI Elektra Posted at 2017-12-24 23:49
https://www.youtube.com/watch?v=krqYn5a5cT0
eso se rompe con mirarlo, ojo, asi que esa avería lo deja inutil, ojo con apretar que vi dos rotos, de esa pieza vale 2 euros cien piezas, sin ella no chifla, la averia placa nueva; 400 pabos o 100 en mercadillos baratos, ojo
2017-12-25
DJI Elektra
AMARdji2017 Posted at 2017-12-25 16:17
Hi, sir. Please write in English for better assistance. Thanks for your support.
2017-12-27
outbackmac
yes everything seems to be working at this time.  thanks for all the help
2018-1-2
