JohnnyElvis
Austria
Hi Guys,
since the <250g regulations will affect me soon as well, I'd also like to "add some lightness" to my drone. According to various channels I was able to gather some information about component weights. Maybe someone can help me to finish/double check the table below.
Take off weight - 303g
Middle Frame (with battery adapter, motor wires, antennas) - 46,6g
Upper Shell - 10g
Bottom Motor cover - 1g each
Propeller - 1,25g each
Core Board (no fan) - 70g
Heat sink - 4g
Gimbal/Camera - ???
Front Sensors - ???
Bottom Sensors - ???
Battery (no housing) - 80g
Battery Housing (bottom) - 10g
Battery Housing (top) - 4g
My idea is to transplant the electronics into a new body. Or to be more precise a skeleton, housing will probably be a fragile mix of balsa wood and plastic bag. Battery will probably end up as "non removable". Unfortunately I'm missing information about the exact angles of motors. I'm also not quite sure about a safe sizing of arms (thickness). Maybe you can help me brainstorm and provide some ideas
