OTG Cable will not connect and is instead charging my phone???
2589 10 2017-12-19
BROLL
Searched and couldn't find anything on this. I have used the otg cable before and it has worked now it won't connect and is instead charging my phone when plugged in. I am pretty sure I'm doing everything in the correct order.
1. I turn on the controller and wait for light to stop blinking.
2. Plug OTG Cable into my phone (Google Pixel 2XL)
3. Plug other end of OTG cable into the controller
and at this point in the past it would launch the DJI Go4 App, but now instead just starts charging my phone. I'm currently using App version 4.1.15 and aircraft, controller, and batteries are all up to date. Any ideas on what might be going on?
2017-12-19
S-e-ven
Flight distance : 5922034 ft
Thailand
Mine is and was always charging the phone with a very low current.
But it is still connecting.
Let me guess, you have updated to .800 firmware?
Edit: I am still on .701
2017-12-19
Wachtberger
Flight distance : 261509 ft
Are you sure that you have plugged the cable in the right direction? Try it the other way round, just to be sure. With GO 4 version 4.1.15 there shouldn't be a problem using OTG.
2017-12-19
Wachtberger
S-e-ven Posted at 2017-12-19 09:51
The firmware update .800 was only for the Spark, not for the RC. Thus at least RC connectivity should not be affected as it is reported here.
2017-12-19
S-e-ven
Thailand
Wachtberger Posted at 2017-12-19 09:54
Does that mean, firmware .800 is working with otg?
2017-12-19
BROLL
It is in the right direction because my phone is usb type C and the controller is micro usb and I have updated to the .800 firmware.
2017-12-19
BROLL
Quick update for anyone else who may have this problem. I simply rebooted my phone and everything is working again. Thanks    S-e-ven and Wachtberger for all your help it is greatly appreciated!
2017-12-19
BROLL
S-e-ven Posted at 2017-12-19 09:57
Yes just checked and ran a quick test flight and everything is work as it should running .800 firmware and DJI GO 4 version 4.1.15 (Android) with an OTG Cable!
2017-12-19
Wachtberger
Yes and without any issues. See attached screenshots (the gimbal overload message is only there because I forgot to remove the protection cap):
2017-12-19
Wachtberger
BROLL Posted at 2017-12-19 11:36
Thank you BROLL and you are most welcome! :-)
2017-12-19
DJI Elektra
DJI Team
Hi, sir. Please note that OTG is not fully tested and I would recommend you use the wifi connection instead. Thanks a lot.
2017-12-24
