Jyunte
Flight distance : 2103150 ft
Last month, we shared new information about the FAA’s UAS registration requirement, which Congress has reinstated.
On December 12, 2017, President Trump signed legislation that will reverse the earlier court ruling in the John Taylor case and restore the FAA’s UAS registration requirement, including for AMA members.
AMA believes that registration makes sense at some level, but has pushed for a more reasonable threshold. While we address these issues, members will be legally required to comply with the FAA registration requirement.
Following are some frequently asked questions. Answers are based on the information available at time of press and are subject to change.
Q: If I already registered, do I have register again?
A: You will not have to register again since this bill simply reverses the John Taylor case. We will share more as details emerge.
Q: Do I need to register again if I requested a refund and asked to be removed from the registration list?
A: You will need to re-register only if you received FAA confirmation that your request to be removed the database was honored.
Q: I did not request a refund/removal from registration database, will my registration number and expiration date stay the same?
A: Yes, your registration number and expiration date will remain the same unless you requested that the FAA remove your information from the database, and received FAA conformation of this removal.
Read the full FAQ on the AMA website.
