Hello,
My Mavic pro battery control board damaged , Can buy it seperatly ? , i cant send battery for warrenty purpose. No one accept it to send it
can get this control board only ?
Thanks
I tried to send it for warrenty , But no shipping companies accept battery , thatswhy open it, Also am only one time fly with this battery , So its battery is fine , need change only its control board ,
Warranty void for sure as soon you tamper with it. You need to get that professionally disposed now. Nice to see the inside of one though - thats a first.
if any one have a damage battery , its helps me , i mean battery (li-po) part damage and circuit part working , then i can re use battery again, Because my battery never use, I mean only one fly, So Battery so healthy, Just need its circuit board only
Fox, we don't recommend that you repair it or continue using it for the concern of flight safety. Since you had opened it, DJI might not provide warranty for it. Please contact support@dji.com for a further help.
DJI Thor Posted at 2017-12-21 20:33
Fox, we don't recommend that you repair it or continue using it for the concern of flight safety. Since you had opened it, DJI might not provide warranty for it. Please contact for a further help.
I tried creating a ticket for my battery doing the same thing and never got a response.
Just some thoughts.
Have you done a search on the forum to find users with bloated batteries that cannot be replaced under warranty?
Have you any experience with soldering circuit boards? You will notice the two main leads have a large ball of solder at the connection. A lot of heat applied very quickly is needed to minimise the damage to the glued on coper circuit. Typically this breaks away and makes repair very difficult. If you get lucky, you still have to solder the new leads. I suggest you get several battery boards to practice on.
The large area connection, the solder, is vital so there is negligible resistance at the joint. Frankly, I think you risk losing your drone in this endeavour. Good luck anyway.
