lannes
Flight distance : 4465 ft
That seems like normal behaviour for the battery, when you press the battery once to check capacity it will show solid lights and flashing lights and then it will go off in a few seconds
Can you turn the battery on while it's in the spark, will the AC start up ?
One reason why you may not be able to charge the battery in the Spark is that the usb port may not have enough power to charge it, I think you need 3 amps at least, but you may already have other batteries charging properly through the usb
Have you checked all the cable connections into the charging transformer ?
What is your charging set up, are you using the DJI Battery charger hub ? |
