Can't update Flysafe database
1487 14 2017-12-23
josephayay
Philippines
Can't download flysafe database. Can you please help me on this? Thanks!
2017-12-23
josephayay
Philippines
P.S don't mind the wifi signal.
2017-12-23
Vendex
Flight distance : 16722920 ft
Bulgaria
josephayay Posted at 2017-12-23 08:57
You can try with DJI Assistant 2
2017-12-23
josephayay
Philippines
How? I already did that. Nothing happens.
2017-12-23
BagoDJIoperator
Flight distance : 1077608 ft
Trinidad and Tobago
Connect your drone to the RC and try and update that way. Hopefully it works.
2017-12-23
Punchbuggy
Flight distance : 483166 ft
Hi. Not sure how you're connected after getting the update message.
When you get the message on your smartdevice, attach the device directly to the craft using the cable provided. Note that the craft must already be powered up for the device to recognise the connection when the cable is plugged in - this has caught me out before.
2017-12-23
Vendex
Bulgaria
Punchbuggy Posted at 2017-12-23 14:10
You are right and the RC should remain on while the update is in progress, as I remember?
2017-12-23
Punchbuggy
Vendex Posted at 2017-12-23 14:48
No, I don't believe it does, Vendex. The smart device is directly connected to the craft (and using it's wifi connection to download the update), so the controller doesn't have a part to play. At least, that's how I recall it... ;-)
2017-12-23
josephayay
Philippines
I'm connected directly to the aircraft. And connected to the wifi. Still stock in zero. Just want to know how they update it in DJi Assistant. Do I need to click something?
2017-12-23
josephayay
Philippines
No solutions here? Anybody from DJI. Please.
2017-12-23
Vendex
Bulgaria
When you connect with DJI Assistant 2 a window should appear on screen telling you for this update
2017-12-24
josephayay
Philippines
Nothing appears on screen.
2017-12-24
DJI Diana
Flight distance : 2408 ft
josephayay Posted at 2017-12-24 04:35
Hi Josephayay, please connect the drone to the DJI Assistant 2, then refresh the firmware. Please also reinstall the APP, the connect the drone to the APP, see if it works.
2017-12-25
josephayay
Philippines
DJI Diana Posted at 2017-12-25 00:45
https://www.youtube.com/watch?v=0XNlhlDXMAs&index=3&list=PL8-vxWY64sBNqoF71lWL0ZCztUE9JaFK8
Already did that for how many times. Still, nothing happens.
2017-12-25
steve_in_TX
Flight distance : 112871 ft
What was your resolution for this?  I'm having trouble with this and a DJI Spark.
2018-1-6
