Ernesto Stifano
Hi everybody, I'm working on a hexacopter with an ARM based flight controller designed by me. I purchased the E310 propulsion system and it has been difficult to find detailed documentation. The ESCs behave a little different from the ones I used before, I can't figure out the start up routine, I mean, the system works, I'm able to control the motors, but the only check ESC seems to do when powered on is for the throttle to be in the min position. What about min/max calibration? (pulling throttle lever back and forward, is no longer necessary?), does the ESC need other setup parameters to be sent from the controller or viceversa? . My flight controller sends PWM signals, E310 user manual indicates 30-450Hz signal frequency 3.3-5V amplitude, since I tested the system with a Hitec Radio, I wanted to verify those numbers before connecting the E310 to the actual flight controller. Thank you very much! |
