01.04.0703 firmware
2287 17 2017-12-23
Dpastell
Unboxed my new p4p obsidian and the shipped firmware is at 01.04.0703.  Checked for update and it is current.  I figured I would post this as I have not seen a newer one on here yet.
2017-12-23
Jenee 2
Flight distance : 7852129 ft
Well lucky you. I wonder when the rest of us will get it.
2017-12-23
CraigR
It probably doesn't work with the older P4Ps because the paint is a different colour
2017-12-23
Dpastell
Anyone else have this firmware?
2017-12-25
BalugaLou
Just installed this today in my new Christmas Present. You will need to update the controller as well. This process was not intuitive to me but I got it done. I loaded the drone took it outside and was getting video link and disconnect errors. The App updated the controller and boom...good to go. Two flights in the bag.
2017-12-25
BagoDJIoperator
Flight distance : 1077608 ft
Trinidad and Tobago
there was a new update that was released today, check again
2017-12-25
Cinefilms
Flight distance : 118829 ft
Dominican Republic
Really?!?!?!.....i was told by some forum administrators that the obsidian had THE SAME FIRMWARE AS PHANTOM 4 PRO..Susan actually was the one who told me that.
https://forum.dji.com/thread-118570-1-1.html
2017-12-25
Aerial-Image
Flight distance : 1452408 ft
My P4PO arrived Tuesday 21st Dec was set-up and activated all fine latest FW nothing to update, it was wrapped and place under the xmas tree - Just opened today 25th Dec from the Christmas wrapping paper and it now needs updating .... so yes there's a new FW out there.... OH hum...
2017-12-25
Cinefilms
Dominican Republic
Cinefilms Posted at 2017-12-25 12:04
2017-12-25
Aerial-Image
No its been updated -
Taken from the DJI website -  Updated Dec 25 P4PO -
Featured -
Date : 2017.12.25
Aircraft Firmware : V 01.05.0300
Phantom 4 Pro Remote Controller Firmware : V 1.4.1.0
Phantom 4 Pro+ Remote Controller Firmware : V 1.2.2.0
DJI GO 4 App iOS : V 4.1.20
DJI GO 4 App Android : V 4.1.18
What’s New?
 Added Pano shooting modes (with DJI GO 4 v4.1.20 or higher).
 Optimized GEO Zone Management.
 Fixed a rare issue where progress could stall during gimbal auto calibration.
2017-12-25
DJI Susan
Hi there, the latest firmware is V 01.05.0300. Make sure your internet is solid and check again.
2017-12-26
fans61699a75
Flight distance : 24897940 ft
Hi dj susan can you please advise if the specs in the picture are the correct ones? Also for remote ,database.
The remote controller says 01.04.01.00 as at the announcement it says 01.04.1 is that the same then? Please advise
2017-12-26
fans61699a75
Hello dji please respond if above versions are the correct ones, thanks
2017-12-26
alt_2992
You had better luck than I did.  Both my remote and unit are updated with the latest firmware but now my remote has a purple LED illuminating where it's usually green and I don't have any video feed.  It's now telling me that my gimbal is disconnected. The LED's are flashing on the drone itself as if it was updating and the small LED light next to the SD card slot is red. I have attempted to downgrade hoping that this make resolve my problem but it's still doing the same thing. Has anyone experienced this problem are have any idea as to fix it? I have had mine for a while and have never experienced this issue.
2017-12-26
Cinefilms
Dominican Republic
DJI Susan Posted at 2017-12-26 02:30
can i have access to the 01.04.0703?......since you told me the obsidian shares same firmware as phantom 4 pro wonder if i can install this version into my drone.
thanks,
2017-12-27
DJI Susan
fans61699a75 Posted at 2017-12-26 03:44
Confirm that you have got the latest version of aircraft, controller and database. No worries.
2017-12-27
DJI Susan
Cinefilms Posted at 2017-12-27 08:06
thanks,
I'm afraid not. It is the default factory number of obsidian currently, and all are same with the white version.
2017-12-27
DJI Susan
alt_2992 Posted at 2017-12-26 20:49
Hi there, please refer the below and try to reset the RC: Turn on the RC, hold the C1+C2+Shutter button at the same time,  turn off the RC and turn it on again, then connect the APP and update the firmware in overall status.
2017-12-28
