DJI assistant will not recognize spark
11461 13 2017-12-24
gaar
cannot get spark loaded in assistant
tried many sequences
any help appriciated
2017-12-24
DJI Elektra
Hi, sir. Please try to change a PC for further check. Can you charge your spark through charger? I would recommend you change a cable and ensure that you download the latest version of DJI Assistant 2.
2017-12-25
lannes
Flight distance : 4465 ft
Have you turned the Spark on when it's connected via USB
2017-12-25
gaar
lannes Posted at 2017-12-25 02:27
yes have tried the start up sequence several ways and times.
Do not have another machine to install on.
It seems to be a driver for the usb
do we know what driver that needs to be installed
running windows 8 on a 64 bit machine
2017-12-25
Wachtberger
Flight distance : 261509 ft
gaar Posted at 2017-12-25 06:00
This problem seems to happen sometimes with Windows 8 and 10. For me as well it did not work in the first run. Re-install the DJI Assistant and watch out for a message requesting you to accept drivers from unknown sources. For me it is working well since.
2017-12-25
lannes
From what I can see it's just the normal usb driver.
It could be the issue with the driver signature enforcement in windows 8
See the second half of this PDF to turn it off for the 64 bit version
http://download.support.xerox.co ... nt-Win_8_8.1_10.pdf
2017-12-25
Wachtberger
lannes Posted at 2017-12-25 14:11
This will certainly help, thank you!
2017-12-25
Neeon
Flight distance : 453701 ft
Fiji
tried and tested it works!
2017-12-25
gaar
this is the fix
re boot and sequence properly
thank you
2017-12-27
OlderDJIPilot
Flight distance : 118 ft
Wachtberger Posted at 2017-12-25 14:24
I am having the same problem. Every time I start Assist 2 it defaults to an Inspire 2. When I installed the Assist 2 I also installed the extra drivers it presented. I removed the software and reinstalled it. This time it didn't ask to install the additional drivers. I guess I have to fish around and find the drivers and get them off the computer.
I started Assist again with the same issue. I does not recognize the Spark. It is looking for a Inspire 2...
What do I do now?
2018-10-17
OlderDJIPilot
What do I do now?
2018-10-17
Wachtberger
OlderDJIPilot Posted at 2018-10-17 10:43
What do I do now?
I have sent you a PM.
2018-10-17
mayur bhadra
India
M6 dji spark is not beeping while preaaing the power buton for 3 or 6 or 9sec. It on's perfectly bit doesnot connect to remote or phone
2019-8-23
djiuser_pocSw7NWP6yf
mayur bhadra Posted at 8-23 19:22
The same issue I even tried to connect my spark to pc running windows 7 but usb not recognizing help pls
2019-10-4
