Upload Failed because of Timeout issue
2006 4 2015-4-17
rahmiefecan.gma
Flight distance : 6683 ft
Turkey
Hi,
my setup is S900 , A2, dji OSD Mark II and 900 mhz datalink. Pc GS is connecting , i draw mission then i try upload it but  "Upload Failed because of Timeout " error message .. any suggestion? Thanks
2015-4-17
HMArnold
Flight distance : 24012 ft
I have flown many autonomous missions using a Windows 7 laptop without any problems.
The other day i tried my MS Surface Pro 3 with Windows 8.1.
Everything went fine until I attempted to upload the waypoints, then I got that same message.
I noticed that the COM port didn't show as it usually did, but seemed to work fine.
I reworked everything with my normal laptop and flew the mission.
My hope is to try the Surface again on the bench to see if I can find any changes to get it to work.
If I find anything I'll repost
2015-4-19
rahmiefecan.gma
Turkey
HMArnold Posted at 2015-4-19 19:38
The other day ...
hi,
i m trying with windows 7 ultimate, drivers all installed ,  tonight i try upload mission again and it iis done.. i  not understand what is wrong.  yesterday with same system it was not working but today worked..
2015-4-19
HMArnold
The only thing I can suggest is to watch that COM port to make sure it doesn't change after you first connect.
2015-4-19
rahmiefecan.gma
Turkey
HMArnold Posted at 2015-4-20 03:36
The only thing I can suggest is to watch that COM port to make sure it doesn't change after you firs ...
thanks for your help, i will watch it
2015-4-19
