S-e-ven
Flight distance : 5910961 ft
Thailand
djiuser_yUsyV8Q Posted at 2017-12-29 01:06
Yea I think the records will still reflect the parameters but for my case the drone doesn't detect it automatically during flight. This means then even when I bring it extremely close to the ground, it doesn't do warning beeps nor prompt landing (I guess it doesn't detect). And usually when not in gesture mode if you put your hand below the drone, the drone will move up to create distance from your hand, but it doesn't in this case so the sensing isn't functioning correctly. I just tried it briefly and did not go further since it is risky to fly in that context.
You missunderstandig:
it is not the drone, it is the App! Not showing it.
For android users there is a downgrad to before 4.1.18 the solution.
Btw: The 'drone' (app) is still givin all the infos it can: It is telling you (literally) "max altitude reached" (try with settings to the legal ~60m over sealevel ;-), still showing batterylevel, only not in percentage, but the green line, with RTH point, battery warning points. Another indicator, for me, that the App got deliberately coded, NOT TO show the parameter if in otg mode. |
