heliman
Denmark
The spark batteries can’t use a charger like the cellpro.
They have a charger built in, which needs exactly 13.05V to work correctly.
The fly more power supply gives exactly that, and each battery controls it’s own charging current. It can't be forced to go faster.
When charging 3 batteries simultanously, the 3.83A power supply may be the limiting factor, slowing charging a little down.
The normal procedure for charging a lipo cell pack is to start with a constant current while watching cell balance.
If one cell has higher voltage than the others, the balancing circuit will discharge that cell while the others are charging.
The discharging circuit is slow (to avoid excessive heat), so it may ask the charging circuit to slow down.
When the battery is near full, the charging circuits goes from constant current to constant voltage mode, which is slow.
