Altitude negative in flight-record (IMU)
3267 20 2017-12-26
Raploc
Flight distance : 22598 ft
Hi,
When I watched a recorded flight in the DJI GO app I suddenly saw that the spark registered a negative altitiude. It's not the first time I've seen this so I uploaded the last time to PhantomHelp:
https://tinyurl.com/yccc3nw9
If you go to time 6m 1.6s you'll see the IMU go to 0 while the VPS is showing 12.5 ft and after that the IMU shows negative numbers until I start to rise again. So the IMU and VPS are completely out of sync. The app never showed me negative numbers during the actual flight so I'm not to concerned but it is a strange choice to show the IMU altitude in the app during playback.
My drone is on firmware 0900 and the app on build 4.1.22
2017-12-26
hallmark007
Flight distance : 9827923 ft
Sweden
Up to approx 30 ft your correct height is reflected through VPS, above this height your Aircraft will now use barometer to measure height you will see when VPS rises above this height it will read 0 and your correct height will be measured by barometer, barometer is very accurate so no need to worry, and when lowering your altitude below 30ft VPs will again kick in.
You may also notice when flying low over buildings or trees VPs kicking in and you may get incorrect values for altitude, other aircraft like P4Pro have capability to give readings in telemetry.
2017-12-26
Raploc
hallmark007 Posted at 2017-12-26 11:39
It's not the vps that is showing the negative numbers, it's the IMU. I understand how vps works, I showed my son at home how it works with a polka dot blanket on the ground with the spark hovering above it. When he gently pulled the blanket the spark would follow it. My guess is that the IMU gyros are not precise enough to estimate the altitude but the app uses the recorded IMU data in the app during playback.
2017-12-26
hallmark007
Sweden
Raploc Posted at 2017-12-26 11:58
I didn’t say it was VPS I’ll explain again, VPS is used when taking off and climbing to 30ft and landing or flying below 30 ft this is your correct altitude above this your correct altitude is measured by barometer.
IMU as used in phantomhelp is barometer measurement.
2017-12-26
Raploc
So the barometer is not reliable in my case or it accumulated a lot of error readings. It was windy but that was above the tree line not at 4 meters.
2017-12-26
Griffith
Flight distance : 98537 ft
OR... the other possibility is that there was a change in atmospheric pressure during your flight.  Even a change as small as 0.01 psi can result in almost 20 ft change in calculated altitude.  In any case your takeoff altitude is always 0.  I don't think the IMU does any recalibration during a flight, but probably  only reports a moving average of the last few data points.  If your pressure sensor is flaky it may produce an erroneous average, but I don't think, in that case, you're readings would be as consistent.  My vote is pressure change.   Butas Hallmark commented,  VPS is much more accurate when within range and over a relatively solid surface and is insensitive to atmospheric pressure (mostly :-) )
2017-12-26
Raploc
Griffith Posted at 2017-12-26 13:04
I think you are right, a drop of 1 hPa would be about 8 meters (24 ft). That would explain the difference in height. Too bad the spark doesn't calibrate the barometer with the vps system during the flight and that it is used as the height reference in the app during  playback.
2017-12-26
Wachtberger
Flight distance : 261509 ft
And there is one more element to take into consideration if I may add it: If the take off point is higher than the following flight area, there will be also discrepancies in altitude measurements (negative values), or am I wrong?
2017-12-26
Raploc
I mean a rise in pressure not a drop, the IMU would then show the spark to be at altitude when it landed not below the reference point it took during take off.
2017-12-26
Raploc
Wachtberger Posted at 2017-12-26 13:27
True, but in my case that wasn't the issue.
2017-12-26
Wachtberger
Raploc Posted at 2017-12-26 13:31
Because the Netherlands are so flat? Please accept my apologies for this little joke, but I just couldn't resist ;-).
2017-12-26
Raploc
Wachtberger Posted at 2017-12-26 13:39
Yep, the ground here is pretty flat
2017-12-26
Wachtberger
Raploc Posted at 2017-12-26 13:50
Being your "neighbour" I know that quite well. Good that you took it as meant :-)
2017-12-26
DJI Elektra
Hi, Raploc. Did it happen frequently? I would recommend you cool down the AC and take off your drone after a few minutes if you encounter this situation again. It may be caused the change of the atmospheric pressure of the environment.
2017-12-26
Raploc
DJI Elektra Posted at 2017-12-26 23:51
Hi Elektra, I've checked other flight records and it seems to happen after 4-5 minutes of flight. The ambient temperature was low on all occasions. Somewhere in the range of 4 to 10 degrees Celsius.
Edit: Is this normal behaviour at these ambient temperatures? Does anyone else recognise this with his or her Spark?
2017-12-27
Raploc
Hi Elektra, see my reaction/question, is this normal behaviour for the Spark with these low ambient temperatures?
2017-12-27
Griffith
Correct.  A common problem for those flying down slope.
2017-12-27
Raploc
Shameless bump. Any admins out there who can provide an answer to my question regarding the "overheating" at low ambient temperatures?
2017-12-27
DJI Elektra
Raploc Posted at 2017-12-27 22:14
Sorry for the late response. Please provide me your DJI Account so we can look into your flight records for further analysis. Or you can PM me about it.
2017-12-29
Raploc
DJI Elektra Posted at 2017-12-29 04:43
Send via PM
2017-12-29
DJI Elektra
Got your PM. Please wait patiently.
2018-1-3
