hallmark007
Flight distance : 10017858 ft
Sweden
wetordry Posted at 2017-12-28 13:31
I have attached a pic of the start of the flight. It shows the AC yawed to the left, although i flew it straight out away from me...not once did i yaw to the left. Thx for the explanation on atti vs opti, makes sense now.[view_image]
I suppose question I was trying to ask , did you lose gps and go to Atti mode, I will explain below what happens to your aircraft when this happens , if this happens.
Why would a compass error disable GPS?
Orientation (compass data) and position (GPS data) are different but related.
When the Spark is moving and getting position information from the GPS that tells the Spark that it is travelling in a different direction from what it's getting from compass data, The Spark programming can't work with the data conflict.
The solution is to drop data from one source and since the Spark can't fly without a compass but can without GPS, it's the GPS data that gets dropped.
This may not have happened but it’s no harm in knowing how your AC works in such situations. |
