Betamace
Flight distance : 2133 ft
No. The P3S remote only connects to your display device with wifi.
For your second question, the range you will get between the remote and the aircraft is dependant on many factors. Best way to improve range is by pointing the remote at the aircraft with the antenna positioned vertical and parallel to the aircraft. Insure the aircraft is flying high enough so that the radio signal is not blocked by buildings, trees, etc.
