TB48
751 16 2017-12-29
fans3f16d419
Flight distance : 25758 ft
Norway
Hello. I have a TB48 battery. When i slide the battery in the drone and start it up it says in the overall status battery error. After about 2 seconds it says overall status normal. When i check the battery cells everything seems normal, can i trust this battery?
2017-12-29
Mark Guille
Flight distance : 2031818 ft
Jersey
Do you regularly cycle this battery (discharge until it turns off then fully recharge)?
Mark G.
2017-12-29
fans3f16d419
Norway
Mark Guille Posted at 2017-12-29 07:25
Mark G.
I have discharge the battery 1 time since i bought the drone. Just bought the drone about 3 weeks ago. How often do you recommend i discharge?
2017-12-29
Mark Guille
Jersey
fans3f16d419 Posted at 2017-12-29 07:28
It is recommended that you cycle them every 10 - 20 charges.
I would try cycling it and see if the error goes away, also, fly cautiously for the next few flights, go easy on the sticks.
Mark G.
2017-12-29
fans3f16d419
Norway
Mark Guille Posted at 2017-12-29 08:05
Ok. Thanks for good advise
2017-12-29
Mike9129
Flight distance : 3977569 ft
how exactly do you cycle it can i ask?
run it down to nearly flat and then charge up full again or is there a setting somewhere?
2017-12-29
fans3f16d419
Norway
Mike9129 Posted at 2017-12-29 09:02
I belive you have to fly until you reach about 10% and then just leave the drone with the power on until it is completely drained. Immediately after you charge it fully up.
2017-12-29
DTK
Flight distance : 1943159 ft
If you have bought it 3 weeks ago, don't waste time for offering your own solution. Just return and replace. This is your consumer right, don't take others problem into your own hands. Everytime you discharge your battery, its capacity will diminish. Deep recycle hurts it more. So why you want to sacrifice your battery life and your time for an pre existing issue.
Caution! If you have a battery problem don't fly the drone off the ground to fix that problem.
2017-12-29
Mark Guille
Jersey
fans3f16d419 Posted at 2017-12-29 09:11
If the battery needs cycling, the percentage cannot be relied upon, that is one of the main reasons to cycle it. The "Show Voltage" option in the app should always be selected. Better yet, read up how Lipo's work and how to look after them properly. They are, after all, the main thing preventing our birds from smashing back down to Mother Earth!
Mark G.
2017-12-29
DTK
Excellent advice, Mark.
2017-12-29
DJI Elektra
China
fans3f16d419 Posted at 2017-12-29 08:11
Hi, sir. You can also check the battery status in Aircraft Battery. The difference between battery cell should not over 0.1. If it is over 0.1, please try to fully charge the battery.
2017-12-30
Elektrica
Flight distance : 9674836 ft
Happened to me as well a long time ago. I ended up changing the battery for safety concerns. You never know, better safe than sorry I went through maaaannnnnnyyyyy batteries and I only had one or two issues over time.
2017-12-30
Mark Guille
Jersey
Elektrica Posted at 2017-12-30 02:09
Do you have any old one you want to get rid of?
Mark G.
2017-12-30
Elektrica
Mark Guille Posted at 2017-12-30 02:34
Mark G.
I do not have them anymore. I sold them with the Inspire1 and I think they were sent back for repair / substitution
2017-12-30
Jlarcher
Flight distance : 2743376 ft
Mark G.
I have Inspire 1 with a questionable battery. Would ?  Let me know sometime
Jim
2018-11-10
A CW
Flight distance : 13838848 ft
Jlarcher Posted at 11-10 22:35
Jim
Deep discharge the battery and if you still experience problems with it then return it if still under warranty or dispose of it following local regs for lipo's.
2018-11-16
Mark Guille
Jersey
Elektrica Posted at 2017-12-30 02:39
Hi Jim,
How much do you want for it?
Regards
Mark G.
2018-12-5
