ghost_ATX
Flight distance : 1277703 ft
Before flying, definitely read the manual. It has 4 pages devoted to how RTH works. There is a certain distance you need to be from your RC and your home point has to be set correctly or it won't work.
If you check out these forum threads, you will see it emphasized over and over and over and over by experienced pilots - sometimes abreviated as "RTFM". SO MANY issues that new pilots have with fly-ways, crashes, wonky RTH, jankety controls, RC not connecting, app not working right, losing connection due to incorrect antenna position, camera settings not functioning the way they should, horizon tilted, etc. can be solved by simply reading the manual first and following its instructions. This isn't a toy - its a very, very complex machine.
Also, YouTube has literally thousands of tutorial videos posted by Mavic pilots that cover anything you could possibly want to know. But definitely read the manual.
Firmware and manual downloads are at the DJI website under Mavic/Downloads, and you can download the current manual here;
https://dl.djicdn.com/downloads/mavic/20171219/Mavic%20Pro%20User%20Manual%20V2.0.pdf
