Does Simulator Mode require a connected and powered Mavic Pro?
4145 9 2017-12-29
mz-in-norcal
Flight distance : 1005049 ft
I don't understand it.  If I don't have my Mavic Pro powered and connected, I can't use the Flight Simulator? Huh?
I'm afraid to try anything in the flight simulator because I don't want the Mavic to start flying around my family room.  Someone please explain to me what is going on?  I assume a flight simulator only SIMULATES flight and doesn't actually fly anything around.  But then, since my drone is on and connected, I don't want to risk making any assumptions.
-mz
2017-12-29
cstephens10
Flight distance : 170545 ft
yes. You have to connect your mavic, power it on and remove the blades and use it as you usually would
2017-12-31
mz-in-norcal
That just is crazy. What’s the logic in that?  I’m glad flight simulators for 747s don’t require that you power them up and leave them sitting idle.
2018-1-2
ianc2
The (stupid) logic is that the simulator is pulling flight configuration information from the Mavic and hence it needs to be powered on. You're right, it doesn't make any sense...
ianc
2018-1-3
Franklyn Sulive
Part of The “sense”  is DJi may be preventing use of the simulator by non-owners and making their simulator a freeware app used by everybody with a phone. Ever thought of that?
2018-1-11
Dorset_Horn
Flight distance : 93379 ft
Franklyn Sulive Posted at 2018-1-11 07:15
What a devious mind you have, sir.
2018-1-25
Harry Pottar
Flight distance : 13163 ft
I would see that as a bonus, get a bunch of new people hooked on the simulator then they would go out and buy the real thing. Even bring out a separate app, I would have practice a lot while making the decision to buy or not
2018-1-25
mz-in-norcal
Now that I've had this Mavic for a while, I find that there's a bunch of stuff that they need to do better, around the same idea:
1. Why do I need to have the Mavic on in order to view Panos?  Let me download the individual images to my phone once, and then view the panos without powering up the Mavic.
2. There needs to be a way to power the Mavic from the charger, without a battery connected, which would allow you to access the datafiles, the images and videos, or use the Mavic as an SD card reader, or use the Simulator, without running a battery down AND ensuring that when powered that way, the props would NEVER rotate.
3. The simulator needs to be a separate app on the phone.  In fact, the app should be split into at least two apps: a flight controller and everything else.  Why do I need to have the same app that flies the Mavic, also help me shop at DJI?  Or to access and read these Forums?  Make a Flight app and a DJI community app.  Maybe even split the video editor out of the community app.
4. Allow me to add a second phone to the additional USB port, so I can let my kids use it to view the flight.  This second phone will be a pure viewer and would allow no control changes or preferences changes.  It's merely a viewer of the video feed from the Mavic camera.
2018-2-5
azswift
Flight distance : 13819 ft
mz-in-norcal Posted at 2018-2-5 00:04
I like the secondary device as a viewer!
2018-2-7
Easy Ed
Flight distance : 41414 ft
nicely done - thanks for sharing.
2018-11-2
