X7 + 16mm + CENDENCE (MF - Analog slide focus problem)
1116 8 2017-12-30
AIRPOWER VERONA
Flight distance : 842244 ft
Good morning, CONFIGURATION: Zenmuse X7 + 4 Lens sets + Cendence on a INSPIRE 2
TEST: we have Test the MANUAL FOCUS by analog slide on Cendence and X7
  • X7+24mm lens:  The MANUAL FOCUS by analog slide on Cendence     (TEST OK) and working perfecly
  • X7+35mm lens: The MANUAL FOCUS by analog slide on Cendence     (TEST OK) and working perfecly
  • X7+50mm lens: The MANUAL FOCUS by analog slide on Cendence     (TEST OK) and working perfecly
  • X7+16mm lens: The MANUAL FOCUS by analog slide on Cendence     (PROBLEM) the analog slide not working on cendence but Manual focus working perfectly on DJI GO 4
I have also calibrate lens but the problem not disappear
Can other USERS test if they have same issue?
PLEASE DJI TEST IT or solve the problem in the next firmware update
Thank you
2017-12-30
Airlfix.dk
Flight distance : 8077667 ft
Denmark
This focus dial is probably nothing more than just a marketing gimmick. I have never seen anybody been able to actually use it. It never works!
DJI can make drones fly - but they have no idea how to make solid camera software. It would be great if DJI spend some of their billions on hiring quality devs and great camera software engineers so that their products could actually do as they promise in their marketing material.
2017-12-30
AIRPOWER VERONA
Airlfix.dk Posted at 2017-12-30 09:39
with 24,35,50mm the dial working well ..... only with 16mm there is this problem
2017-12-30
Airlfix.dk
Denmark
AIRPOWER VERONA Posted at 2017-12-30 10:11
Really? Because it's not working on my 50mm either?
2017-12-30
AIRPOWER VERONA
Airlfix.dk Posted at 2017-12-30 12:38
I have do the first install and activation of the X7 with 16mm lens mounted; and update the INSPIRE-2 to the last version.
I don't no if this is the cause but now only the 16mm not working with the FOCUS ring on the cendence.
Other lens I have install for the first time after the UPDATE..... and all working 24,35,50mm with the FOCUS ring on the cendence
2017-12-30
Hi AIRPOWER , just to verify, what is the Cendence firmware you are running at the moment? Thank you.
2018-1-2
AIRPOWER VERONA
DJI Mindy Posted at 2018-1-2 02:48
Cendence firmware: 02.00.0030
2018-1-2
AIRPOWER VERONA Posted at 2018-1-2 11:57
AIRPOWER VERONA, thanks for your quick update, our engineers have been aware of this issue and are working on it, please wait for the next firmware release, we apologize for the inconvenience caused and appreciate your patience.
2018-1-3
Airlfix, we apologize for the inconvenience caused, our engineers have been aware of this issue and are working on it, please wait for the next firmware release, appreciate your patience.
2018-1-3
