DroneDriver
Flight distance : 1164226 ft
DJIPilot-IceBox Posted at 2018-1-2 11:15
Thanks for your input. I also have a Huawei phone, the mate 9. It is prepaid and the screen is 5.9 so I might try to use that too. My problem is that, I can't get the side port to work, along with the cables that came with the drone. I was able to charge my RC but not use it to connect to the RC and aircraft. Are you using the bottom USB?
I have found that you need to open the setting to allow the connection via the charging/ data port. It tries to charge the phone and will not connect to the app,
The symptom was the phone at 100% charge would disconnect, immediately. I actually let the battery drain, a bit and tried it at 88% battery on the phone and it worked fine. But the correct setting solved that one.
Interesting. I have not been successful using the USB on the controller. I really don't care, for now, didn't try very hard to solve that, yet.
Hope that helps... |
