I have a Phantom 2 plus and it keeps disconecting from the camera on my phone. It say connection broken or cannot connect to camera. any tips on what i should look into first?
At what sort of range does it do this ? The flat top of the range extender must be pointing at the Phantom.
Is your phone looking for an internet connection ? Turn off mobile data, or go into airplane mode and then turn the wifi back on.
Do you have ANY other device you could try? Even a friends/family members phone? If you did, and it did not connect to that I would start looking at the extender. If it did connect, the problem is with your device. Simplest way to isolate the problem.
Also, are there any other wifi networks in the area? The Phantom wifi likes to be the strongest signal.
I see the phantom listed it is connected to it. The last time I used it was october it worked fine then, it has been sitting on top of my gun safe ever cence so it has not been dropped.
If you are close to home, try forgetting your home network. I found that if anything goes wrong my tablet would connect to my home network instead of the Phantom 2 Vision Plus controller.
