Ex Machina
Flight distance : 1806362 ft
skyluke9 Posted at 2018-1-1 13:20
Mounting it on my computer, copying the files to the disk. I would normally do this with Lightroom, but as Lightroom complained about corrupted files I also tried to copy the files manually and open them with Windows Media Player. Some of them will parly work (but be shorter than what was previewed in DJI GO), some don't even appear as valid video files (probably the header gets corrupted in that case).
Ok, a couple things:
You should always format the card in the Mavic.
I'm trying to rule out corruption that happens when you attempt to transfer files from the card to your PC, as some have reported having problems with slower USB hubs and problematic Windows drivers.
Video on Go 4 is not the same video as what's on the MicroSD card, unless you've manually downloaded the video to Go 4 (and this only works with video resolution formats your smart device can handle, which varies from device to device) -- this is why a downlink video may preview fine on your phone but appear corrupted on the card.
Most smart devices can handle 1080/30 video, so you could try shooting at 1080/30 and then seeing if it can be successfully downloaded to Go 4, and comparing that attempt to directly connecting your PC to the card. If Go 4 download works, but transfer to the PC fails, then you've got a problem in the transfer chain. If Go 4 downloaded video proves to be corrupt, then you might have a bad card or a firmware issue. In that case of the former there are some things you can try:
if you are connecting the Mavic via cable to a USB hub, try connecting it directly to your desktop, bypassing the hub.
If you are connecting the MicroSD card to a card reader that's not integrated into your desktop/laptop and that's not connected to a hub, try a different card reader. If it's connected to a hub try bypassing the hub.
If you have access to another computer that has an integrated card reader, give that a try.
If you can confirm the video is corrupt on the card, and not failing to download because of format compatibility problems with your phone, then if an appropriate replacement card doesn't solve the issue, you can try restoring your Mavic's firmware. I had a problem a few versions back with corrupted image files that I fixed in this way, although it took several passes of refreshing the Mavic to solve the issue.
Hope this helps, and good luck!
