luciens
Mark The Droner Posted at 2018-1-14 07:01
Must to add to the mayhem...
Apparently, from what I've read in forum posts, the more-modern DJI batteries are set up so that 0% is not actually 0%. This makes it very difficult to get your battery down below the catastrophic 3.0v cell level. This also explains how sometimes you might read that 5% is an appropriate deep discharge level, whereas it used to be 8% a few years ago.
this seems to be true. I usually take my batts down to about 35-30% as it's reported in the telemetry, but the cells are around 3.8v resting. On a LiPo, that normally corresponds to a little over 50% total capacity left in the batt.
On all my other regular LiPos, I put in just under half of the stated mah-capacity of the batt if I run them down to 3.8v.
So yes the smart logic in the DJI batts probably gives more of a usable-without-destroying-me percentage left rather than the total capacity period. I've only gotten down to about 10% one time and the resting voltage was still around 3.7v, which is fine.... |
