Phantom 3, camera dead after crash!
LeTobbz
Flight distance : 80889 ft
Thailand
Good Evening!
As the topic is written my camera on my phantom 3 is dead after a crash in to a tree. The problem is following:
After the crash the flexcable and the arm to the camera broke, but both the arm and cable has been swapped for new parts. Now when I start the drone the gimbal "spins" as it should but sets in "standard" in an angle furter down then before. The drone connects to the remote and phone without issue but the camera wont connect.
Does anybody know what this issue is due to? And how I might solve the issue.
Best regards
LeTobbz
2018-1-1
JensenHay
Does the camera actually say its disconnected, or can you still take pictures to the sd card?
Have you tried to auto calibrate the gimbal?
Have you relinked the controller?
https://www.dronefly.com/blogs/n ... roller-on-phantom-3
These are the things I see on the other threads, I'm in a similar situation so just posting some info to help get you going.
Good luck!
JensenHay
2018-1-6
LeTobbz
Thailand
JensenHay Posted at 2018-1-6 11:25
I will try this things.
Thanks for your help, I'll get back if the problem is solved.
Best regards
LeTobbz
2018-1-7
