FCC Hacked App
128570 246 2018-1-1
Blue17
Flight distance : 56010 ft
With deejayeye-modder you can simply turn 4.1.22 into FCC. The steps aren't very difficult to follow imo. I personally like the new feature to enter the device/camera view without already being connected a lot.
2018-4-9
flydav
Flight distance : 184226 ft
If FCC mode is all you are after there is no need to get into config files or hacking anything. If you are on android just download a fake gps app then you connect your Spark and it will prompt you to change WIFI region settings. DONE! After that delete your fake app but every time you start your spark you will receive the same message about WIFI region (this time ignore clicking cancel) That's it
With iOS (like myself) you need to download to your computer an app from the app store called Xcode (there are videos on youtube) the concept is basically the same it's just a bit trickier because you need to use Xcode which was something I wasn't familiar with. After you successfully used Xcode delete the app that has been created in your iPhone/ipad and you're done!
This way there is no hacking at all just tricking ;) I don't think dji would be upset if you play this trick rather than using a modded app with all the consequences that could derive from it in terms of voiding the warranty or risk of flyaways, etc. Honestly I wouldn't hack anything, I decided to use FCC because in CE my spark gave me connections problem after only 100mt away from me.
2018-4-10
Jos A
Flight distance : 73209 ft
Blue17 Posted at 2018-4-9 22:03
4.1.22 hasn't OTG support, better use the 4.1.15 version
2018-4-10
Blue17
My OTG works perfectly fine in the modded 4.1.22
2018-4-19
fanse5394b5d
Flight distance : 128471 ft
Blue17 Posted at 2018-4-19 05:11
In what way is the App moded?
2018-4-19
ZmaroSobrinho
Flight distance : 7058809 ft
Brazil
hey, you dont need any hacked app, see my video that i teach how to - in portuguese
2018-4-19
NedUK
Flight distance : 555262 ft
If anyone knows a method for iOS in interested in knowing it. Not sure if I would implement but interested...
2018-4-19
BrilhasMuito
Flight distance : 3745554 ft
Brazil
Hahahahahahhahaha
2018-4-19
Jos A
ZmaroSobrinho Posted at 2018-4-19 11:17
Depending If want waypoints and other mavic flightmodes on your Spark, yeah you can do the fake gps thing.But  the modded had more advantages.....
At the end we all want the modded app because we want everything what is possible on the Spark.
Soon we have the Mavic Air dronies for the Spark......
2018-4-20
Juan01
Jos A Posted at 2018-4-20 04:57
Is it the same using this FCC patch than using the DJI GO 4 MOD app?
Is it better to use any of those instead of fake gps?
2018-6-3
Jos A
Yeah the modded app (bases on 4.1.15) has it all. If you use Fake GPS you have only the FCC.
Be aware, in your log file DJI can always see that you are in a different country than flying (fake GPS)
2018-6-3
fansf88fdec0
Norway
Jos A Posted at 2018-1-9 23:46
4.1.15 FCC mod and orginal 4.1.22 on one device works! with app cloner premium version.
Both apps works perfectly.First install the mod app, then clone with app cloner, change icon color and name, then uninstall mod app, install the cloner app with new name and color, then download 4.1.22 from android store.
Helo
I have problem with my p4 pro.
Can you help me with nfz? I need better options. Nom i have limit up 500m and mybest distance its 700m with bad video quality.
I can send you big buttle with whiskey or money if you help me.
Best regards
M
2018-7-21
Jos A
take a look @ https://nolimitdronez.com/
2018-7-27
fanse5394b5d
Jos A Posted at 2018-7-27 09:18
Thanks, did think of using that, but might be a step too far for me, the DJI GO 4 MOD app  is mostly a DJI app that I am comfortable with.
I would probably try Litchi if the Mod'ed app gives probs. But so far, so very good
2018-7-27
Jos A
It's from the same makers. It's for people who cannot make a mod app by themselves
2018-7-28
fanse5394b5d
Jos A Posted at 2018-7-28 01:48
It has a couple of features I don't want or need.
Namely, unlimited height and removal of NFZ restrictions, I still fly within CAA guidelines, but want to ensure a good connection to spark by using FCC transmission levels.
When I fly using CE transmission the connection is sketchy at best
2018-7-28
Jos A
You can choose in the client version what you want, if you want only FCC it can be done
2018-7-29
wimherman
Flight distance : 208556 ft
Norway
tellmike-SPARK Posted at 2018-1-2 03:20
So where is the best place to discuss more about this topic? I live in a CE area so would be interested in knowing more about the experience.
Hej,
/whisper mode on
You need a fake gps app, and make it availbe as fake gps in delopment meny. Starte fake gps app, choose some region in USA. Start Go4, acknowledge wifi regio settings (FCC), close fake GPS app. Nexttime u start Go4 cancel the reguest for chaning the Wifi region.
/whisper mode off
Så enkelt är det ;-)
2018-7-29
fanse5394b5d
Jos A Posted at 2018-7-29 04:18
But I already have what I want using DJI GO4 MOD 2.0.
If it ain't broke don't fix it
2018-7-29
djiuser_RU6wO5HIz5wG
Flight distance : 986348 ft
Greece
Kyokushin Posted at 2018-1-2 07:54
I am using only hacked app because:
1) FCC - its just safer. Stronger signal will give me a more time to reaction in a case of fly-away. Its not about a range. Its about reliability and safety.
2) anonymity - DJI will do not know where i am and what i do. I am not logging to their account, not sending and uploading anything. I am completely offline.
Agree 100% but it's difficult to admit it in a forum like this!
2018-7-29
Legendary_Daniel
Flight distance : 3770 ft
Philippines
for those wanting to switch to FCC mode using iOS without an android or mac device.
just use your windows computer.
download an android emulator called, bluestacks. change your location via the inbuilt location spoofer of bluestacks (i.e some region in the US)
then download the dji go app.
connect to your drones wifi using your computer wifi.
and confirm the wifi network change that pops up.
when you connect your drone to your iOS phone just select cancel when the app asks you if you want to change regions.
viola, FCC mode the easy way. let me know if that helps you.
2018-7-31
Sparky_17
Flight distance : 62349 ft
i'm not a huge advocate of hacking an app or device.  So i'd say no.
2018-7-31
Sparky_17
This is a hilarious reply .. thanks for making my day
2018-7-31
djiuser_bQj7nNctDXtv
I am searching for a valid method to change to FCC Mode in Germany ? Can someone PM me ? I would be very happy when I can get some help
2018-8-15
Ps: I have the Mavic Pro
2018-8-15
Flighty
Flight distance : 1977175 ft
Croatia
Try "Floater" I fly FCC mode in a CE environment...
2018-8-15
fanse5394b5d
I don't think FCC mode is relevant to the Mavic Pro.
It's only of concern for drones that use WiFi bands for communication between RC and AC. Namely the Spark and possibly Mavic Air.
Forcing FCC in an CE country wont make any difference to a Mavic Pro
I think the Mavic Pro uses Occusync, a proprietary DJI communication system.
2018-8-15
Greg F
Flight distance : 944308 ft
Must be a US thing... Never heard of it here in AUS
2018-8-15
Jos A
fanse5394b5d Posted at 2018-8-15 23:55
True but why not if it is available.... even force boost(1.5 watt) can be done.
2018-8-16
fanse5394b5d
Jos A Posted at 2018-8-16 03:51
Worth a shot.
How would you do it?
I have tried fake gps apps and although they work, they give a location in the USA. Not ideal when I'm in the UK.
2018-8-16
Jos A
I will pm you( is for the mavic pro)
2018-8-16
fanse5394b5d
Jos A Posted at 2018-8-16 05:33
Thank you
2018-8-16
Inspire_Max
Flight distance : 9211303 ft
Please, pm me too. Thanks.
2018-8-19
Jakab Gipsz
Hungary
MikB Posted at 2018-1-2 01:44
Whilst I agree with everything you say fanse5394b5d, I did find the response from  Rjrolyn VERY funny. The problem is, irresponsible fliers will take advantage and make regulations worse for us than they are now. I suspect this forum is not the best place to discuss this subject.
It's ridiculous to limit everyone for a few stupid people. This is a collective punishment and not ethical!
What would you say if you were only going to produce cars that would be limited to 90km / h for now because some people do not comply with traffic rules?
Do not limit the software, everyone takes the weight of their actions individually, as it does elsewhere.
2018-8-21
Jos A
Jakab Gipsz Posted at 2018-8-21 14:48
you can go to the dark side with a mod app. You have it all but fly safe and under the rules of your country
2018-8-22
Wolferl
Flight distance : 23793 ft
Austria
Jos A Posted at 2018-8-22 06:59
+1
Cheers,
Wolferl
2018-8-23
S.J
Flight distance : 322454 ft
Kuwait
fansf88fdec0 Posted at 2018-7-21 10:54
Helo
If this is true, What is the difference between P4 and SPARK other than camera .
2018-8-23
Jos A
S.J Posted at 2018-8-23 07:10
flighttime??
2018-8-23
Mattgus
I also having an Mavic Pro that i want to change to FCC
Can anyone help me? i have tried the Android and fake gps app without any luck.
I fly with IOS (i dont own an android gadget myself)
2018-8-28
Jos A
Android?, I will PM you I think you do it wrong.
2018-8-28
