Not able to activate pairing mode on Spark
1199 3 2018-1-2
fansd49a9ff8
Norway
My Spark aircraft will not activate pairing mode after (possibly incomplete) software update in november. The Spark gives not response keeping the button in for 3, 9 or more seconds - hence impossible to reset the Spark. My PC does not recognize the Spark when USB-cabled and using the DJI Assistant 2. Has it died?
2018-1-2
helmarw
Flight distance : 12730 ft
does it do anything when you switch it on? what happened during the software update, that you think its incomplete ?
2018-1-2
fansd49a9ff8
Norway
I dont get any response from the Spark, except from the fact that it turns on. When I keep the button in, all four led lights on the battery are blinking, but no other response like the expected beep(s)  or changed response from the front/back led lights on the aircraft.
I believe  the software update stopped at at 80% and never completed.. I did the update via the RC/WIFI.
2018-1-2
DJI Elektra
fansd49a9ff8 Posted at 2018-1-2 23:42
Hi, sir. Can you charge your spark via USB cable? I would recommend you change a PC to flash your spark with DJI Assistant 2. If you fail many times, please contact us and send it back for check: http://www.dji.com/support.
2018-1-3
