Ocusync Air System for RC Car
1484 9 2018-1-2
FatStoge
Hello,
I recently ordered the Ocusync Air system for my DJI Goggles RE and was hoping to install the camera and unit onto my RC Car (Traxxas X-Maxx with TQi radio). I've seen plenty of videos and instructions on installing it on other drones but nothing for RC Cars. How would it be wired? Can you run it to the receiver for power like other accessories? Also, off topic, can the feed be viewed elsewhere other than the Goggles?
Thanks in advanced!
2018-1-2
userc700ed709a
United Arab Emirates
Hi. Did you have any luck connecting the Ocusync Air Unit to the battery? I’m trying to do the same as you but there are no instructions whatsoever on the type of connection needed for the batteries! Appalling instructions. I have also contacted DJI’s support and they got back to me with: “sorry we don’t have any information on this. It’s a DIY connection”. I haven’t been able to power the unit on yet!
2018-1-13
mphertenberger
Flight distance : 117874
Singapore
The transmitter seems to require S3/S4 LiPo batteries, so traditional 7.2V batteries used in an RC car probably won’t work. Unless you have an ESC that can connect to a LiPo.
Would be keen to find a way of doing this...
2018-1-16
FatStoge
userc700ed709a Posted at 2018-1-13 11:25
Trial and error. I bought a 3s FPV battery on Amazon with an XT30 connector. Then I ran an Xt30 to male JST connector to a female jst connector with two terminals at the other end. Those terminals slipped right onto the two power leads on the UART cable. Works!
2018-1-16
userc700ed709a
FatStoge Posted at 2018-1-16 19:12
Great to hear that it worked. Thanks. How many Ampere battery should I buy? There is no data on consumption on the manual and the technical support was unable to answer me. Is a 1500 mAh battery sufficient in your opinion for 30 minute downstream of video signal only? Cheers
2018-1-20
FatStoge
I just used a 3S FPV drone battery from Amazon. Mine was 450MaH
2018-1-24
userc700ed709a
FatStoge Posted at 2018-1-24 11:55
In the end I bought a 1250 mAh 3S battery but I’ve noticed that it gets drained quite fast.. 30 min max probably.
I am able to record only on the Goggles RE’s SD card though. Anybody knows how to record directly on the Ocusync Air Unit’s SD card? In what format should it be formatted? There seems to be no option in the menu on where to record..
Other issue that I have is that every time I have to plug and unplug the battery and repeat the linking procedure between the Ocusync Air unit and the Goggles RE multiple times before I finally get the image on the Goggles. Anyone has the same issue?
The instructions provided in the box are totally incomplete and frankly unacceptable for a commercial product! You need to take it to an electrician just to make the necessary connections to attach it to a battery!!
2018-2-5
Jamesjts
Flight distance : 279373
Hi looking to do this as well and put on a 1/8 crawler. Wondering if you guys had any heat issues not having flight air flow over the occusync unit.
2018-3-6
fanse4b92006
Flight distance : 1222179
Ukraine
DJI stated - Ocusync Air System is usable for RC car, boat etc..
THE MAIN QUESTION to DJI team - HOW it's usable (for video transmition only or FULLY including control signal)?
If it's fully usable please specify how!
I'm a big fan of DJI but unfortunately - no anwer fm your good team untill now!
FYI
I bought DJI Goggles combo (Ocusync Air System included) 4 months ago. Tried to wire up my HPI Vorza with Ocusync Air unit throgh SBUS to PWM decoder but vainly - seems like there's not SBUS coming out fm this Ocusync Air unit! How or by means of what I can get proper PWM signal in order to have possibility to ride my RC car?
Thanks to DJI in advance for quick reply.
2018-3-26
fansbfa40521
Flight distance : 5422
Hi! Awsome news!
I have heard that Ocusync and Traxxas may block eachother out. Did you experience anything like that?
What is the range for video/rc control?
1-4 05:01
