Aardvark
Flight distance : 384432 ft
Good point, Background refresh was off on tablet (worked well), background refresh was active on iPhone 6s plus (there are things I like to keep updated). So that may be the difference between the two, I'll have to do a test with refresh off on phone for duration and see if that helps.
Edit:- Did a bit of testing here, background refresh disabled on the iPhone 6s plus made no difference to the reports of disconnects when switching between applications.
This is not something I would normally do when flying (jumping between App's) but did get caught out once or twice when adjusting screen brightness, and simplest fix was to remove and reinsert USB plug on RC. Other than that I've never had any disconnects in flight using the iOS devices.
