Gulfstream
Flight distance : 98996 ft
Geebax Posted at 2018-1-2 14:52
Without you describing the situation in detail, it sounds like you are being limited to 30 Metres height by 50 Metres distance. If so, this is not to do with the NFZ, but you are required to log onto DJI to release the flight limits. You only need to do this once, preferably at home, but stay logged in even though you shut down the app and aircraft later.
....been there done that... -- not being rude, but that is NOT the problem. I can login just fine etc. This is related to the file that has been downloaded, NOT installing. Yes, the F/W has been refreshed etc.
In Detail--- The Steps:
1) I connect my Android Device via the OTG to the A/C
2) I Turn On the Controller
3) I Turn On the A/C
4) I Get Prompt To Update NFZ Database - I Accept
5) Download Begins ---->>>> I get the "Finish" prompt, I do so.
6) I Shutdown A/C
7) I Shutdown Controller
8) I restart Android Device
9) I Connect and Start Controller
10) I Start A/C
11) Device lists choices of apps - I choose Go4
12) Version Check etc.
13) Go Fly
14) Verify I'm Logged In At Office and Again At Location
15) Flight Is Limited.
16) I switch Apps and Fly on my way
