ropate
Flight distance : 856847 ft
DJI Thor Posted at 2018-1-2 19:02
Just to verify, did you fly the drone in Sport mode, or did you? And how about the wind speed around, is there a gusting wind? Please do more tests and see if it happens frequently, before the test, please check the anti-drop hooks are mounted properly, make sure that the propellers are in good conditions with no damages, and also, avoid flying when there is a strong wind. Please keep us updated if the issue persists.https://www.youtube.com/watch?v=hnXekYjEJA8&index=16&list=PL8-vxWY64sBNLusG0MvxD4Dm-tX4cnvzX&t=12s
hi Thor, thanks for this. The device was brand new out o the box pretty much as i bought it en route to Tahiti.
There was wind, but nothing significant and in fact was blowing from behind in that footage mentioned above.
Anti drop hoks, i presume you mean the ones that keep the gimbal in? All 3 are where they should be base don the videos i've seen for that.
And definitely not sport mode, which is just tried and is awesome!
It did happen again on acceleration this morning. Very odd.
Have ordered PP filters to see if that helps....i needed them anyway. |
