Turning Drone when it's flying towards you.
651 5 2018-1-2
fans507e98d7
when the drone is flying towards me, what can I turn on,  and how, to turn it to my left, by turning the control to the left? I have the  p se
Thx
2018-1-2
ALABAMA
Flight distance : 10422228 ft
Everything will be in reverse order when flying toward yourself.
2018-1-2
Mark The Droner
Flight distance : 2917 ft
Sounds like you're asking about IOC home lock.
https://www.youtube.com/results?search_query=phantom+3+SE+IOC+home+lock
2018-1-2
solentlife
Flight distance : 1087530 ft
Latvia
I know OP does not want to hear this ............ but the BEST solution is to learn control .....
Yaw stays same as its revolving the model .... stick left = CCW revolve ... stick right = CW revolve
Slide to side as you view reverses - but in fact it is same ... Its your VIEW and coordination that flips over ...
Up / Down is same ...
Fwd / Back as in Slide to side appears to be reversed - but again its your VIEW and coordination that has changed ...
It really is best to learn to control without using software ....
Its funny actually ............ I have flown RC for over 50yrs ... and I still at times stop, hover and think before giving stick command on the P3 ... why ? Because its different to normal RC in various ways.
Nigel
2018-2-10
Giammi
Flight distance : 847795 ft
When I was flying plane models, I had to face how to learn piloting them without any helps.
So one good hint was:
- When your flying away from you, right-stick to the right → the plane roll right and goes right
- When your flying towards you, right-stick to the right → the right side of the plane goes up (roll left from your point of view) → the plane goes left.
Visually this helps a lot!
Otherwise, you can try to have a look to the course lock intelligent flight mode. Maybe that can help you.
2018-2-10
B-727
Thank you. I'll give it a shot.
Mike
2018-2-12
