6 Tips to Make Your Aerial Videography Stand Out
123Next >
18052 84 2018-1-3
DJI Grace
Flight distance : 405039 ft
Do you sometimes find your aerial footage dull and wonder how you can give it a boost? Killer drone shots are not that hard to achieve. Below are 6 aerial videography tips to make your aerial footage stand out!
Combine Different Axis Movements
Your footage can hardly stand out when your drone only moves forwards or backward. To add more depth to your footage, you can try out different combinations of axis movements. For instance, simultaneously fly up and backward or fly sideways while flying up and forward. Make sure to be gentle on the remote controller’s sticks as slow and steady movements make your footage more cinematic.
Recorded with Mavic Pro
If you still need some time to get the hang of drone operations, we recommend you use Tapfly mode. This intelligent flight mode sends your drone flying steadily in the direction you tap on the screen so that you can focus on other operations, making complex flight combos easy to achieve. Just press and hold the target area on the screen and wait for the GO icon to appear. Then tap GO to confirm, and your drone will fly towards the target location. It’s almost like you have an experienced pilot assisting you.
Orbit
Circling an object can add a tremendous cinematic impact to your footage. You can navigate a circle manually by maintaining the target in the middle as you fly sideways while yawing the opposite direction.
Be aware it takes a lot of training to fly a perfect circle manually. Luckily, you can take advantage of the Point of interest intelligent flight mode. In this mode, your drone will automatically circle at a smooth rate, during which you can quickly adjust height and radius. However, note that there’s no obstacle avoidance when flying sideways. So, you’ll need to tap pause in case of emergency.
Fly at Low Altitude
Many people assume that aerial videography is all about gaining height. Though high altitude flying can accommodate an ampler shooting space, low altitude flying can show objects in detail and create an immersive experience. Additionally, when you speed up, you can easily convey an intense feeling to your footage. But pay attention to the flight environment, especially the changes of obstacle height, to ensure flight safety.
Follow the Subject from Different Angles
Following a subject from behind is a classic filming move. But since it’s easy to film from different angles with your drone, why not try them out?  ActiveTrack can assist you effortlessly keep the subject in the center of the frame no matter which angle you take. Trace mode will follow the subject as it moves away even if they change the direction. In Profile mode, your drone will fly parallel the subject. It will stay the same distance away from the subject. You can always adjust the framing of the subject by using the tilt dial. Consider different combinations to make your footage more interesting. Always pay attention to the flight environment when flying sideways or backward.
Sideways Movements
Want to reveal the surrounding landscape from another perspective? Strafing movements take care of that! Choose an object to start, then move to the side and let the subject slide across so you can show the landscape behind. Your footage will have a more intense sense of space when it’s shot with a wide-angle lens.
Avoid Sudden Movements
Don’t make sudden adjustments unless it’s for safety reasons as an unnecessary push of the remote controller stick may ruin a good shot, as demonstrated below. Maintain the preset direction and keep the gimbal motion smooth. Additionally, remember to tap the record button a few seconds in advance so that you won’t miss the ideal moment.
Do you find these shot techniques and maneuvers helpful? Try out some new maneuvers and share your stunning footage with us!
The content origins from: BUYINGGUIDES
2018-1-3
A CW
Flight distance : 13838848 ft
Great tips!
2018-1-3
Monsinho
Flight distance : 272490 ft
Sweden
Great tips in short format!
2018-1-3
BigBird2
Flight distance : 883645 ft
Good tips and with video.
2018-1-3
Kuya Kano
Flight distance : 797913 ft
Philippines
Tip #7:  MAKE SURE your UAV is recording.  -I can't tell you how many times I tapped "record" and it didn't record, rather recorded every other clip where I was getting in position.  Make sure the video timer is rolling.  Don't miss that perfect shot.
2018-1-3
DJI Grace
Kuya Kano Posted at 2018-1-3 20:28
This is really important as well
2018-1-3
Kuya Kano
Philippines
DJI Grace Posted at 2018-1-3 20:29
LOL, you'd think flying is the most difficult part of the operation?
2018-1-3
dansmar
Flight distance : 422149 ft
Thanks for the tips
2018-1-3
Roy C
Flight distance : 4692 ft
Philippines
Make sure you bring SD card! haha it almost ruin my Christmas vacation after I found out on site that my SD card is miles away from me, good thing there is a store in town that sells low class one. Got no option but to buy it and hope for the best.
2018-1-3
DJI Grace
Kuya Kano Posted at 2018-1-3 20:39
every part is not simple for me since i am so new
so i always bring my friend with me when flying the drone
2018-1-3
DJI Grace
Roy C Posted at 2018-1-3 21:50
at least you got one at last!
2018-1-3
Nebuchadnezzar
Flight distance : 3428747 ft
Thanks for shatre !!
2018-1-4
Colin G4GBP
Flight distance : 42533 ft
Thank you for sharing your tips. I will try to remember some of these manoeuvres when flying conditions improve. Currently blowing a hooley!
2018-1-4
DJI Grace
Colin G4GBP Posted at 2018-1-4 01:18
take care when flying!
2018-1-4
Wachtberger
Flight distance : 261509 ft
Happy new year Grace and thank you for this very good new tutorial!
2018-1-4
BerkoZg
Flight distance : 2628 ft
Croatia
Great tips. I will use it in my next vid.
2018-1-4
fansb004b644
en posible bolar dod drons fiferentes de el mismo telefono?
2018-1-4
Woe
Flight distance : 4129268 ft
Great tips thanks dji Grace
2018-1-4
FlyingFish82
Flight distance : 3662503 ft
YES!!! that happens quite often, if there is not real  good signal between remote and drone! its really important to build awareness of the information display panel on phone/tablet/screen!
2018-1-4
Gianluca Vassal
Flight distance : 629747 ft
Malta
Thank you for the interesting tips!
2018-1-4
lucass34
good to know
2018-1-4
Montfrooij
Flight distance : 2560453 ft
Again, great tutorial!
2018-1-4
FXF
Flight distance : 68123 ft
Austria
...good and short help for making my footage better - thank you DJI Grace
2018-1-4
Dockater
Flight distance : 139649 ft
What else to expect, good tips and well documented. Thanks Grace.
2018-1-4
czechmark01
Flight distance : 1078343 ft
Thank you!
2018-1-4
czechmark01
Thank you!
2018-1-4
Harry Pottar
Flight distance : 13163 ft
great tips
2018-1-4
IceBox-Murdock
Flight distance : 43845 ft
Thanks for these tips!
2018-1-4
M.C. Pilot
Flight distance : 10278435 ft
DJI Grace, thanks for the great tips !
2018-1-4
JJLMSU
Flight distance : 37457 ft
Very helpful, thanks Grace
2018-1-4
DJI Grace
JJLMSU Posted at 2018-1-4 18:05
You are welcome!
2018-1-4
DJI Grace
M.C. Pilot Posted at 2018-1-4 15:21
Glad to hear the tips helpful!
2018-1-4
DJI Grace
Dockater Posted at 2018-1-4 12:43
Thank you for your kind comment!
2018-1-4
DJI Grace
Wachtberger Posted at 2018-1-4 02:58
Happy New Year!
2018-1-4
ropate
Flight distance : 856847 ft
awesome thanks.  just got to get my movements mosre gradual
2018-1-4
Little John
Flight distance : 192244 ft
Top tips thanks
2018-1-4
Swedrone
Flight distance : 14066975 ft
Sweden
Combine Different Axis Movements is the key. I try that most of the time, but it takes some practice.
2018-1-5
Bekaru Tree
Flight distance : 15513100 ft
South Africa
TIP 7 - get a devise on which the djigo app and updates work so that you have more time to spend practicing with your drone than you do trying to figure out app problems caused by updates. DJI recomended device list is a poor guide to which devices actually work.
2018-1-5
MKPSG12
Flight distance : 341073 ft
Or in the correct mode photo/video, i've take tons of photos before getting frustrated why it won't just start recording! Why on earth pressing the video record button on the remote doesn't automatically switch modes is beyond me!
2018-1-5
CycleParadise
Flight distance : 385338 ft
Another great tutorial. Thanks for posting it!
2018-1-5
123Next >
