Bashy
Flight distance : 2354357 ft
If it is set to RTH then it must have been blown away as others have said, those prop guard would have been its downfall im sure, they act like sails!! The wind only needs to be 1mph fast than the rth speed and it will not return home, the higher you go the faster the speeds can be, most certainly faster then ground level although not all the time, also every 100m it drops about 1C in temps, not that that had a part in this, just mentioning it in passing,
You need to find out from your met office, how fast the wind speed was at the height you was at and what direction it was coming from, post that in here and i bet the guys can help narrow down the search area base on that information and the remaining battery
Good luck |
