endotherm
Flight distance : 503241 ft
One calculation and estimate of the airspeed on Airdata is hardly conclusive proof of what the wind was doing. All that means is that only one instant during the whole flight, Airdata was able to calculate the forces on the aircraft and estimate the wind direction and strength FOR THAT MOMENT, representing maybe only a couple of seconds of flight time. Wind changes all the time and picks up and drops off, as well as change direction. One data point is useless to show a trend and indicate what the wind was like.
You mentioned that "the drone was controlled easily" while you still had it under control. But then you lost radio contact, and it was out of your control. You might have been able to fly it at 15m/s while you had control, but once you lose control and RTH is engaged, the maximum power it uses is reduced, giving at most 10m/s. If the wind is greater than that, it will be defeated by the stronger wind and carried away. It is meaningless if it was controlled easily while you still had a connection, because the situation is now different and it is flying itself at low power and without a remote connection. We can read the data and confidently say that it was swept away with the wind, even if you cannot see it. It is just a fact. |
