DJI Thor
Flight distance : 13602 ft
Users can change the response speed of an aircraft by adjusting these values. For example, to make the screen look smooth when it changes from dynamic to static, decrease the Brake value.
For EXP, the X-axis shows the physical output of the manipulated stick. The Y-axis shows the logic output of the manipulated stick. Both the two are used to control the aircraft’s motors. The range extends from 0.2 to 0.8. To change the response speed of an aircraft to remote controller’s commands, drag the curves. A greater EXP value indicates a faster speed.
For gain settings, I don't suggest beginners to change it.
And like RicardoGray mentioned, make sure that you have connected the drone before adjusting the settings. See if it helps. |
