you can use only litchi its a mutch better app and it has waypoint mode so you can let the drone fly its own mission you make for it without using the rc but in case just have the rc turned on if you use this.i suggest you download the manual for it before using the waypoint mission.the app it worth every penny
For drones with a Wi-Fi connection (Phantom 3 Standard, Phantom 3 4K, Spark), follow these steps:- Make sure no DJI-based apps (including DJI Go, Litchi and other third party DJI drone/osmo apps) are running in the background. If there are any, force kill them
- Force close all DJI-based apps (including DJI Go and other third party DJI drone/osmo apps). Please note step 1 is not enough. To force close an app, go to your mobile device Settings - Apps - DJI Go (or other app name) - Force close
- Start your aircraft and remote controller if you are using one, and let them initialize for a few seconds
- Connect to the Wi-Fi network of the aircraft
- Start Litchi
iOS
- If you have a Wi-Fi based drone (P3 Standard/P3 4K/Spark): connect to the Wi-Fi network of the aircraft, if you have a USB-based remote controller, plug the remote controller into the mobile device
- Start Litchi
 - Flight Modes: Use this dropdown to change the flight mode.
- Radar: Shows the position of the aircraft relative to the operator's mobile device (Android only).
- Flight Telemetry: Shows altitude relative to take-off elevation, distance from home point to aircraft and speed on all axis. In Follow mode, the distance between the mobile device and the aircraft is shown.
- Show/hide small view: Tap to minimize the size of the small view. Tap on the small view to switch the map and video views.
- Aircraft: Shows the aircraft location on the map. Tap to add a Waypoint or Point of Interest at the aircraft location.
- Mobile Device: Shows the mobile device location on the map. Tap to add a Waypoint or Point of Interest at the mobile device location.
- Home Point: Shows the home point location on the map. To set a new home point, drag this marker to another location. You must be flying in order to move the Home Point.
- Photo/Video Switch: Use to change the camera mode.
- Take Photo/Record: Tap this button to take a picture while in photo mode. Tap to start and stop recording while in video mode.
- Gimbal Pitch Indicator: Shows the current position of the gimbal tilt. Top is +30° above horizon, bottom is -90°.
- Zoom to Mobile Device: Tap to zoom the map to the current mobile device location.
- Unlock Map Orientation: By default the map is oriented towards North. Tap to have the map rotation continuously adjusted to match your mobile device's position relative to north.
- Camera Settings: Tap to open camera settings.
Status Bar - Mode Switch Button: Tap to change the flight mode or to log in to your Litchi account.
- Satellite Count: Shows the number of satellites that the aircraft is locked onto.
- RC Battery/Virtual Joysticks: Shows the remaining remote controller battery percentage. When connected to a drone without remote controller, tap to show/hide the virtual on-screen joysticks.
- Battery Status: This bar shows the status of the aircraft battery. The part in red represents the battery required to go home.
- Aircraft Status: Shows the current aircraft flight status.
- Uplink: Shows the strength of the remote controller uplink signal.
- Downlink: Shows the strength of the video downlink signal.
- Aircraft Battery: Shows the remaining aircraft battery percentage.
- General Settings: Tap to show general settings.
Regaining ControlWhenever the drone flies autonomously, you can regain control instantly at any time using the remote controller's flight mode switch.
For newer drone models (Mavic Pro, Phantom 4, Spark, Inspire 2), toggle the flight mode switch from " " to "S"(sport) mode in order to regain control. You may switch back to " " mode afterwards.
For older drone models (Phantom 3, Inspire 1), toggle the flight mode switch from "F" to " " mode in order to regain control. You may switch back to "F" mode afterwards.
When connected to the drone without remote controller (for example with Spark or Mavic Pro), you can use the red stop button in the left button bar to stop an autonomous flight and regain control. Camera SettingsGeneral camera settings as well as shooting modes (Single/HDR/Burst/AEB/Timelapse) can be adjusted after a tap on the camera settings icon under the shutter/record button.
An exposure info panel is also shown at the top of the video screen when connected to the aircraft.
To set the ISO/Shutter Speed/Aperture/Exposure Compensation, tap on the Camera Settings button, then "Exposure Settings". Camera FocusFor cameras with adjustable focus, tap anywhere on the video preview to trigger autofocus at that location.
For the Mavic Pro, Phantom 4 Advanced/Pro and Inspire 2 X4S, you can set the Focus mode to AFC (Autofocus Continuous) in the camera settings.
For the Mavic Pro, you can also do a long press on the video preview to set the focus to Infinity (everything in focus). iOS only. Exposure MeteringBy default exposure metering is in Center mode. If you wish to use Spot metering, follow these steps:
- If your camera supports adjustable focus, tap on the green square icon at the top left of the video preview to switch to Metering mode.
- Tap anywhere on the video preview to set Spot metering at that location.
To go back to Center metering, tap again on the Spot metering icon and the icon will disappear.
Camera ZoomOptical zoom: For cameras which support optical zoom, hold the RC's C2 button and use the left RC wheel to adjust the focal length.
Digital zoom: For cameras which support digital zoom, use the custom function "Digital Zoom In/Out". Gimbal Roll AdjustmentTo adjust the gimbal's roll angle, hold the RC's C2 button and use the right RC wheel.
