Dual payloads - switching between cameras - Error
1136 6 2018-1-4
Grazer
Flight distance : 354357 ft
I have an issue using the dual camera payloads and switching between each camera. In this example, I am using a M210 / Cendence / CrystalSky / X4s and XT V2
When I first connect, the X4s live view is the primary camera feed. If I switch to the XT, this appears full-screen and the X4s feed reduces. Fine.
If I then want to switch back to the X4s as the primary image, it never restores to the full screen size. Yes, I do have latest frimwares and XT is mounted on the left and X4s as you look at the M210 front onwards.
Please help!
Start Up
Start Up
Switch to XT
Switch to XT
Switch back to X4s - small image!
2018-1-4
dronie326
Flight distance : 810 ft
Same issue for me. Were you able to get it figured out yet?
2018-1-12
rkeihn
Flight distance : 621309 ft
dronie326 Posted at 2018-1-12 08:47
https://youtu.be/mHY87QTzgls
Firmware issue with the Z30 and or XT.  The last firmware mentioned fixing issues with the Z30.  Are you positive Firmware update took?
2018-1-13
dronie326
rkeihn Posted at 2018-1-13 17:34
I haven't updated the Z30 firmware  back since the last firmware release in September. I believe this just started happening after the latest M200 firmware. Everything worked normally before that. I'll try reloading it tomorrow and see if that helps any.
2018-1-17
Olivier Vietti-
Flight distance : 10695331 ft
Switzerland
look at the picture
2018-1-17
dronie326
The gimbal connector configuration is not the issue. They are mounted on the correct connectors.
2018-1-24
COOPDRONEWORLD
Has anybody found a solution to this problem?
2018-9-19
