ESC Error for my P3P
fans6e4461ee
Flight distance : 319314 ft
Hii Susan.... I am also having the ESC Error for my P3P...so plz send link for the FW 1.11.30. ... revert will be appreciated.
2018-1-4
DJI Susan
Hi there, I've received your message in PM as well. The V1.11.30 only fix the ESC issue after firmware update, please check the download link in PM and try later.
2018-1-5
Ghouli
Algeria
Hi Susan, would you please send me the link of FW to fix the ESC issue ? thanks in advance.
2018-1-5
D-r-o-n-e
Hi Susan I was having the same issue and got the firmware from DIANA for my p3p. However I am getting The Maximum Flight Distance Reached error. Do you know how Can I solve this ? I have try to reinstall the app and that has not helped yet. However the ESC error has been resolved after that firmware which Diana gave me.
2018-1-5
DJI Susan
Ghouli Posted at 2018-1-5 17:01
Sorry for the late response. I've PMed you the download link, please check later. BTW, please click the Reply button under one's message if you need one'd attention. Thanks for your understanding.
2018-1-12
DJI Susan
D-r-o-n-e Posted at 2018-1-5 18:22
Sir, may I know what's the current APP version? Could you post the screenshot for better assistance?
2018-1-12
D-r-o-n-e
DJI Susan Posted at 2018-1-12 02:53
Hi Susan,
So I did fly it today again Finally got a change  from all that rain. Sorry for the delay in message. I was getting the Maximum Flight distance reached again, I think around 97 feet or something. Anyhow. I did notice something today which is very interesting so when this is happening all the info which is suppose to be on the app like Return to home altitude and other number for the flight are not there they are 0. So When I close the app and relaunch it and reconnect usb seems like all my setting as like Return to home altitude 45m (Which I set previously) starts showing that is when everything works.  Which tells me it is more of an issue with the DJI GO app.
Now to the version of the app I am posting the screenshot of it.
Also I am using the iPad pro 10.5 inch and I have in the past try to reload the app by deleting it from the iPad that does not work.
However as I said I think I have found a temp resolution to the problem which is close the app and relaunch it until we get all the return to home altitude and other numbers starts showing that is when everything works perfect.
Please get back to me if you know a permanent solution for this once again Thank you so much for all your wonderful help. You guys are amazing !!!
2018-1-14
DJI Susan
D-r-o-n-e Posted at 2018-1-14 15:19
Hi Susan,
Thanks for getting back to us. Double check, the OS of your iPad Pro has been updated to the latest version, right? If yes, I'll forward all info to our engineers for double check. We will come back if there is any update.
2018-1-15
jarda
Flight distance : 148094 ft
Czechia
DJI Susan Posted at 2018-1-15 23:55
hello I had version 1.11.20 with esc, the fix on 1.11.30 is not finished and it is currently 1.11.20+ and still esc. please help
2018-1-16
DJI Susan
Hi Susan,
Sir, I just got the update from our engineers that they need more data for further analysis. Could you help us export the flight records and logs when the issue appeared? Thanks in advance!
1. Export the flight records:
Android: Connect the device to the computer, find the flight records stored in …\DJI\dji.pilot\FlightRecord\, and copy the required flight records to the computer.
iOS: Connect the device to the computer, launch the iTunes, find the flight records in the DJI GO app, and copy the FlightRecord folder to the computer.
2. Upload ALL the flight log (.DAT files) in the aircraft to dropbox and send us the link:
a. Connect your aircraft (USB port at the tail/ head) to a PC using the included USB cable. Turn on the Remote Controller and the aircraft, then open the DJI GO app.
b. Click “Mode” icon to view the “Advanced Settings”.
c. Click “MC Enter Read Flight Data Mode”.
2018-1-17
DJI Susan
jarda Posted at 2018-1-16 09:39
Jarda, just to verify, the firmware update to V1.11.30 is not successful, right? If still no luck, I'm afraid that you may consider to send it in for a fully diagnosis: https://www.dji.com/support
2018-1-17
Fedexx
Flight distance : 451473 ft
Uruguay
DJI Susan Posted at 2018-1-17 19:05
Susan, I'm with the same problem, I can not get out of the ESC error, for PM I passed the link to the .DAT file. I hope you identify the problem. Thank you.
2018-2-2
Simon Dunning
I have the phantom e advance and it’s now saying esc error could you help please email me on simondunning72@icloud.com many thanks
2018-2-3
DJI Susan
Fedexx Posted at 2018-2-2 09:54
Received with thanks! I'll double check with our engineers and will come back later.
2018-2-6
DJI Susan
Simon Dunning Posted at 2018-2-3 21:42
Your message is well received. I've sent the download link in PM, please check later.
2018-2-6
compi
Hi Susan
I would like the firmware V.1.11.30 for the P3A . appreciated
2018-2-6
Fedexx
Uruguay
DJI Susan Posted at 2018-2-6 02:10
Hi Susan, until today without news, I await your response.
Thank you very much for your help.
2018-2-9
DJI Susan
compi Posted at 2018-2-6 02:26
Hi Susan
Compi, I'm sorry for the late response due to the holiday. I have sent you the link in PM, please try later.
2018-2-25
DJI Susan
Fedexx Posted at 2018-2-9 05:43
Fedexx, sorry for the late reply due to the holiday. Our engineers have reviewed all the data and confirm it is a hardware issue. Sorry about this. Please kindly send it in for repair.
2018-2-25
compi
DJI Susan Posted at 2018-2-25 01:06
I'm sorry Susan but i can't download the file please can you sent me a new link,
thanks.
2018-3-9
DJI Susan
compi Posted at 2018-3-9 00:49
thanks.
I've resent you a new link, see whether it works now.
2018-3-11
compi
DJI Susan Posted at 2018-3-11 02:51
Hello DJI SUSAN this link works, i hope the problem is over now,
Thank you very much
Have a nice day
2018-3-11
compi
compi Posted at 2018-3-11 23:52
Thank you very much
Have a nice day
Hello SUSAN, sorry for the  inconvience, the file i downloaded now is not compeet,
the file is als follow: P3S_FW_V01.11.0030.bin.crdownload,  and only 36.6 Mb.
what can i do?
2018-3-12
DJI Susan
compi Posted at 2018-3-12 00:04
Sorry about this. The complete size should be 59.85 MB, I've resent the link to see whether you got the right one.
2018-3-13
compi
DJI Susan Posted at 2018-3-13 02:31
Thanks SUSAN,
2018-3-13
DJI Susan
You are welcome. Please let us know whether it works now. Come back to us if there is any further issue.
2018-3-15
compi
DJI Susan Posted at 2018-3-15 01:49
SUSAN, works fine now, no more errors since I've updated
2018-3-15
DJI Susan
compi Posted at 2018-3-15 12:56
I'm glad to hear this. Wish you have a good time on flying the drone.
2018-3-16
