MrPinaColada
Flight distance : 790082 ft
Ok so I had this idea, I have two lipo batteries hooked up in series for a total voltage of something around 24v. Im assuming it should work but I just want to check here first, say I connect the positive and negative terminals of the batteries to the power brick outlet plugin, do you suppose it would start charging the p4 battery? Im curious because it could be an easy way to charge my p4 batteries if im out in the field with no outlets.
