DJI Thor
Flight distance : 13602 ft
Hi there, please try to check if the gimbal anti-drop hooks are mounted properly, see the tutorial below. Please help to confirm if the drone is in Sport mode on that flight, make sure that the propellers are in good condition, avoid flying when there's a windy weather. Also, please try to fly with the gimbal cover, or if it is possible, try to check if it will have the same effect on the ground outdoor, if yes, confirm again indoor, just power it on on the ground and check it on the app. Please keep us updated if the same issue persists, thank you. |
