marklyn59
Flight distance : 395072 ft
DJI Thor Posted at 2018-1-9 01:16
Hi Marklyn59, we appreciate so much of your feedback, as far we know, it's a false positive, but could you still provide me with the specific version of your BitDefender so we can test it? Thank you so much.
Yes, It's build 22.0.17.209
I should also say that trying to install the new DJI Assistant app fails each time on my Windows 10 machine with Bitdefender. It stops when it's trying to install or rename a file called root.exe so what I did was fired up a Windows 10 VM with no Bitdefender, installed the DJI assistant there with no problem.
Then I went back to my original machine, attempted another install, this time saying "ignore" when it stops at the root.exe issue, and it installs everything except the root.exe
If I try to copy the root.exe from my VM to my real machine with the "ignore" prompt during the install the root.exe won't copy over due to an authorization prompt; however, if I rename the root.exe on the VM to anything.exe it will copy over and I can then run that named file. For some reason, with this version of DJI Assistant, something on my system, doesn't like that root.exe file at all!
