Johan97
Flight distance : 37201217 ft
Sweden
Well, you could scan you own forum if you have not done so yet, you would find 100's of posts//comments about this, but ok, i will give you one more to the 100's....
First of all, a calibration (using the functionality in setting) do not affect the behaviour described below at all.
In DJI Go 4, the compass gadget/widget to the bottom/left (the circular one) do not point even close in the correct direction and it is jereky (jerking around even when the RC/Screen is kept still.
In DJI Go 4, the map is not aligned with the position of the controller/CS (compared to IRL), which in turn do not show the AC icon and the green line leading back to home perpendicular when pointing the RC towards the AC inflight (as it suppose to do in order to help the pilot to keep the RC/antennas perpendicular to the AC).
Its not that it is a bit off, its pointing all over the place, everything from 1 to 359 degrees incorrect (never 0 or 360 degrees off, ie correct, that never happens....)
I have used other screens/tablets/phones before so i now how this is supposed to work and how crucial
(and valuable when it works) this is especially when using directional antennas or extenders.
/// Johan |
