Shoot It WA
Flight distance : 3576476 ft
Noah Pitzer Posted at 2018-1-6 21:43
Glad everything turned out ok!
Wow! You got some serious flying and editing skills! If you had one tip to give me to improve my flying and create videos like this, what would it be?
Thanks! Practice makes perfect, get out and fly as much as you can, watch some Youtube tutorials and find a video style that works for you.
If you are after quality cinematic styled shots try to film in "the golden hour" just after sun up and before sundown.
Use ND filters (especially on the Mavic.)
Plan your shots, look on google earth before you head out to the filming location or spend some time flying the area to work out the most interesting points to film.
Mix up your shots, usually no one wants to watch 5 minutes of footage from the same angle. You don't have to fly really complex movements to make interesting footage, just have a look on Youtube and see what others are doing then get out and practice them.
Try to make smooth slow movements, especially if you are speeding up footage a small shift will look like a sharp jerking motion when sped up.
I like using the cinematic mode for higher speed shots and tripod mode for slower more precise work (you do need to be careful using these modes because the drone is slower to respond to your commands)
Shoot in D-Log or D-cinelike, It looks really flat and boring straight off the camera but comes up a treat when you colour grade in post production.
Speaking of colour grading, try using LUT's (Mlut from Motion VFX is a good free plug in for Final cut pro) they take a lot of the work out of colour grading footage.
Thats a bit more than one tip but hopefully it helps |
