after updating phantom 4 pro plus to latest firmware the update is succesful yet the panorama mode never shows up in picture settings? and now my gimble acts all crazy and flicks to one side then slowly goes back to the other randomly and when changing camera setting profiles. i have never had any problems with this drone at all untill this update someone please help.
have done update with rc connected via cable
rolled back to old firmware
then updated with dji assistant
then rolled back again
and tried rc update again
wiped ssd card reset factory settings nothing is working.
they said this update was to fix gimble problems i had none untill this update
i have rolled back and now that gimble issue is still there i always use this option to flick from my video to picture mode settings and now it disconnects and the camera ends up stuck to the right
So are you currently on the old version on the controller and the bird? They both have to be on the same version or you'll get all sorts of problems.
maybe thats the problem my p4p+ controller never done an update it only updated the aircraft. the aircraft has been rolled back but dont know what the old firmware is for the remote
The newest version for the P4P+ is 4.1.15 and does not has or allow pano mode... DJI has not informed when or if this will be available for P4P+ owners. As usually, we are the last on the waiting cue...
Did you ever figure it out? I tried updating April 17th, yesterday, and now I don't get any connectivity between the two no matter what I have tried. Obviously I have NO idea what to do. I need help asap.
