New Osmo Mobile Battery does not charge
1113 3 2018-1-7
PaulusB
Hi I recieved an Osmo Mobile as a gift.
I have tried charging it with my Aibook Laptop and with an ipad charger, using the supplied Osmo Usb cable.
After the OSMO worked for about 3 minutes it died. The batterij does not seem to charge. No lights light up
when attached to a charger.
What should I do?
Paul
2018-1-7
Marty Markoe
Flight distance : 15135 ft
Could be the charging cable. Shame cable does not have a standard connector. They are available from Amazon with Prime delivery in 2 days. If the cable does not fix problem it is easily returnable at no cost.Marty
2018-1-7
Mari
Flight distance : 1308780 ft
Clean battery-contacts with alcohol and cotton swab... Was suggested by one of the DJI-employees in another thread on this forum. You did remove the plastic film from the battery before inserting it in the Osmo?
2018-1-7
Hi Paul, sorry to read on this.
Like Mari mentioned, please try to wipe the copper sheet inside the battery compartment with 95% alcohol and cotton swab. Let the alcohol air dry. If it does not work, wipe the battery contact with alcohol and cotton swab.
Besides, do you have a second battery to have a try?
Have you tried to turn or pull out the charging cable a little bit to see if it works?
Please let me know if the issue persists, thank you.
2018-1-8
