daver/m
Flight distance : 206503 ft
Check all of the QR adapter mounting screws for tightness making sure they are firmly tightened ! If you remove one use some new thread lock ! You don't need to reef them down but you do need to firmly apply some reasonable torque on the screws , what torque ? Who knows just make them tight !
It sounds like this happened at assembly so I wouldn't be too alarmed as you didn't loose the bird to a crash , hopefully the threads on the motor are not stripped now , try running a good screw part way into the same hole that had the loose screws without the adapter in place and see if it's goofy or loose or has side to side movement .....hopefully the threads will be ok and you won't need to replace the motor. |
