Gimbal position in Waypoint mode
2946 7 2018-1-7
JerryLaurence
Flight distance : 21988 ft
I don’t think it’s possible to record individial gimbal (camera) positions when setting waypoints. Is there any plan to make this important feature available in future?
2018-1-7
ErichG
Flight distance : 74180 ft
Check "Autopilot" app for iOS. It has nice methods for facilitating independent traversal and focus "strategies." Coming from years of working Maya and similar systems for creating complex flight/camera animation - it's pretty slick.
2018-1-8
Upper Limit Fil
Flight distance : 81683 ft
also dji’s ground station pro works great
2018-1-8
JerryLaurence
ErichG Posted at 2018-1-8 18:37
I have used Autopilot for some time now, and I like it. The only drawback for me, though, is that it doesn’t have peaking and histogram which makes getting the correct exposure (in manual mode) more tricky.
2018-1-8
Hey Jerry, we recommend to try GS Pro which can adjust the gimbal Pitch angle at the selected waypoint.
Please check more details here: https://dl.djicdn.com/downloads/ ... _Manual_EN_V2.0.pdf
2018-1-14
JerryLaurence
DJI Mindy Posted at 2018-1-14 23:04
Please check more details here: https://dl.djicdn.com/downloads/groundstation_pro/20171121/GS_Pro_User_Manual_EN_V2.0.pdf
I have had a look at GS Pro. Is it possible to fly to a pre recorded Waypoint, reposition the gimbal and save the new settings. Then do this for each Waypoint in turn? This seems to be the only way to frame shots correctly but I can’t see how this can be done in the manual.
2018-1-23
Ujjawal Animato
Flight distance : 6711102 ft
India
JerryLaurence Posted at 2018-1-23 00:00
GSPro :-  manual you can use it very easily and set as you want hight, gimble speed every.
see this:-
2018-1-23
JerryLaurence
Thanks but the video doesn’t answer my question about editing waypoints and setting camera positions at each Waypoint while in the air.
2018-1-23
