MiniPalourde
A lot of people use the RF-V16 tracker. Personnally I have a lot of problems with it but globally it seems reliable.
You should write your email adress as well as your phone number on the unit. In fact, is it required in Canada.
The app will tell you where was your drone, last time it was able to communicate. If you crashed into a tree kilometers away, you should be able to find it with the Flight log and the mini map on your app. However, if a bird removed the battery and threw the drone somewhere, you would only know where the drone lost its battery
Other suggestion: If you're very high and flying away because of the wind, then you must lose some altitude. The winds are obviously stronger at high altitudes.
If you still can't fight the wind at low altitude and SPORT mode, you should advance in diagonals so you're not directly against the wind. |
