hallmark007
Flight distance : 9827923 ft
Ramee Posted at 2018-1-8 05:07
So you think it is because of power lines. It was a lot above those lines and when compass error happened it was far away of them. I don't understand your logic ?
Yes I was bit away from the bush area I accept that. Just wanted to see how far it will go!
I think the problem is, you flew your spark to 1.3 miles you didn’t have enough battery to get home, so no matter what happened you were going to lose your spark.
You had many warnings speed warning gps no match, which you completely ignored, it is my thinking that in Australia you are governed by CE so max flight 500 metres, so I’m guessing your Aircraft was hacked.
The reason you couldn’t cancel auto land or go home was simply you were out of range for RC.
This is a clear case of pilot error, it has to be said also reckless flying, gives all SUA pilots a bad name. It’s great that you reported it here because it will show others the perils of flying so ridiculously and what the results of this are, and we still don’t know if damage was caused by you when spark landed. |
